With all the bends and twists that go into making these I figured some adjustments were going to be needed, the ones I sent you were .024 and the new ones above are .029 wire a little heavier but I wanted some of each size. The problem with the .029 wire is that the Netcraft wire former comes with a flexible steel rod and it will only make spring coils for .029. I found a piece a bit bigger out in the garage and while it worked I hope to find one piece a little bit smaller so the coils get held better.
Really glad they worked out for you, nice to know they worked the way I made them up.
