Thanks JiggerJohn, very cool. Here's the WW11 US Navy lifeboat survival kit rules. The original wording:
(s) Fishing kit. On everyocean vessel of over 3,000 gross tons there shall be provided in each lifeboatone approved fishing kit consisting of the following equipment:
1pair, gloves, cotton, commercial grade.
1knife, 2 inches high carbon steel blade, thickness of blade 0.060 inch,tempered to test 0.56 to 0.60, well riveted into a wooden handle 6 inches long,3/4-inch wide by 1/2-inch in thickness. Handle to be smooth and shaped, with a1/4-inch hole in end for attaching 3 feet of 10-pound cord. Knife must be ableto float. Blade to be guarded with a water-proofed paper tube 5 1/4 -incheslong by 5/8-inch inside diameter.
1package containing the following items:
1sinker, egg-shaped, with 7/64-inch hole in center, weight 2 ounces, with 3 feetof 10-pound cord attached to wooden handle containing the abrasive stone.
1dozen pork rinds, dehydrated strips 4 inches long, 1/2-inch wide, ends taperedto approximately 1/8-inch, and rounded, one end to have two hook-holds cut3/8-inch and 7/8-inch from end respectively.
1No. 1/0 O’Shaughnessy hook, attached to 6 inches of No. 9 stainless steelwire, other end attached to a No. 5 barrel swivel.
1No. 3/0 O’Shaughnessy hook attached to 6 inches of No. 9 stainless steelwire, other end attached to a No. 5 barrel swivel.
1No. 7/0 O’Shaughnessy hook attached to 6 inches of No. 9 stainless steelwire, other end attached to a No. 2 barrel swivel.
1No. 2 O’Shaughnessy hook attached to 6 inches of No. 5 stainless steelwire, other end attached to a No. 5 barrel swivel.
1No. 6 O’Shaughnessy hook equipped with 3 inches of No. 5 stainless steelwire, other end attached to a No. 5 barrel swivel.
1abrasive stone, size 3/4-inch by 1 7/8-inch by 1/4-inch, firmly cemented withwaterproof cement into a wooden handle of sufficient size to make the unitbuoyant. A 1/4-inch hole shall be in the end of the wooden handle, with 3 feetof 10-pound cord attached.
NOTE:All of the hooks in this package shall be firmly attached to a piece of taperedcork, 1 inch by 3/4-inch diameter maximum and attached to the wooden handlecontaining the abrasive stone.
1set of instructions shall be printed on PAR-A-PAR paper.
1dip net, 12 inches deep by approximately 16 inches across the top and bottomwhen folded flat. Cotton mosquito netting mounted on 12 gage galvanized marketwire. Ends of wire to be securely fastened in a round wooden handle 4 incheslong by 1 inch in diameter, tapered both ends. Over-all length of net foldednot over 16 inches, to be folded once to approximate packing length of 8inches.
3feet of 10-pound cord to be attached to the handle and the front end of net.
1fishing rig No. 1, 36-inch winder, pressed wood or equivalent, containing 100feet of Ashaway 15-pound nylon line or equivalent; 1 No. 6 O’Shaughnessyhook rigged with 3-inch No. 5 stainless steel wire and a No. 5 barrel swivelattached. A split buck shot mounted on line about 6 inches above hook.
1fishing rig No. 2, 1/8-inch winder, pressed wood or equivalent, with 100 feetof No. 12 Ashaway white cotton shore line, or equivalent. Equipped with astubbed mackerel squid jig mounted on a 1/0 O’Shaughnessy hook equippedwith 6 inches of No. 5 stainless steel wire with a No. 5 barrel swivelattached. (NOTE: Hook on this lineshould be light colored.)
1fishing rig No. 3, 1/8-inch winder, pressed wood or equivalent, with 100 feetof No. 24 Ashaway white shore line, or equivalent. Equipped with a 1-ouncefeather jig with white rubber skirts, chrome plated head, rigged with a 3/0O’Shaughnessy hook with 24 inches of No. 9 stainless steel wire leaderand a No. 5 barrel swivel attached.
1fishing rig No. 4, 1/8-inch winder, pressed wood or equivalent, with 100 feetof No. 24 Ashaway white cotton shore line, or equivalent; equipped with a No.1/0 O’Shaughnessy hook on 5 inches of No. 9 stainless steel wire with aNo. 5 barrel swivel attached. A 2-ounce egg-shaped lead sinker with a 7/64-inchhole mounted on a line about 18 inches above hook with knots tied above andbelow lead.
1fishing rig No. 5, 1/8-inch winder, pressed wood or equivalent, with 100 feetof No. 24 Ashaway white cotton shore line, or equivalent, equipped with a No.7/0 gang hook and a 1-ounce egg-shaped sinker, with 7/64-inch hole, mounted onthe line so that this sinker lies directly under the hooks.
1fishing rig No. 6, 1/8-inch winder, pressed wood or equivalent, with 100 feetNo. 48 Ashaway white cotton shore line, or equivalent, equipped with 11/2-ounce feather jig rigged with a 6/0 O’Shaughnessy hook on 2 feet ofNo. 9 stainless steel wire and No. 2 barrel swivel.
1fishing rig No. 7, 1/8-inch winder, pressed wood or equivalent, with 100 feetof No. 48 Ashaway white cotton shore line, or equivalent. Equipped with aspecially constructed spear of approximately 7 inches over-all in length, specialconstructed barb on one end with an open eye on the other end, and a U -shapedattachment brazed to the side of the spear to accommodate blade of oar orpaddle. This item should be constructed of a good grade of commercial steel,the barb to be rounded at the end and back to be concave; protected with awaterproofed paper tube to be 4 3/4-inches long and 5/8-inch inside diameter.
1bib, width across bottom 28 inches, width from end of flap to end of flap, 36inches. Width across the top 30 inches. Length from top of bib to bottom, 15inches. Bib shall contain 12 pockets in which each of the items shall beinserted. All of the edges shall be hemmed and double stitched. Fastened to theend of the left-hand flap shall be a rayon tape 18 inches long by 1/8-inch,securely sewn. Fastened to the right-hand flap shall be 2 rayon tapes, 18inches long by 1/8-inch, securely sewn. 7 1/2-inches from each corner of thetop of the .bib shall be firmly sewn a rayon tape 24 inches long by 1/8-inch.The bib shall be made of olive drab cotton cloth, herring-bone twill, weightper square yard 8.5, minimum thread count per inch in warp 72, in filling 46;breaking strength in warp 125 pounds, in filling 85, pounds. The test to bemade by 1 by 1 by 3 Grab Method.
Allmaterial shall be packed in a metal waterproof key opening can. A 3/4-inch ringwhich shall hinge back flat shall be soldered on the bottom of the container.
NOTE: Each rig shall be marked with sawcuts onboth sides of winder for identification. All hooks and swivels to be attachedwith at least 6 turns of the wire. All lines attached to wivels with asurfman’s hitch with three wraps. All fishing hooks to be bound to rigswith scotch tape. (Approximate weight of kit, packed 3 1/2-pounds.)
Thecontainer shall bear the manufacturer’s name or trademark, together withthe following inscription:
