hooks and spit rings for jigging spoons
jigaglow
I am wanting to order two different sizes of ice jigging spoons. I have no idea what to order for hooks and split ring sizes. spoons are 3/4 inch long and 1/16 ounce and the other is 1 1/8 long and 1/20 oz..thanks guys
0 is the size split rings I say........hooks pending on fish you are after. Trebles for gills #8/ #10. Crappies trebles can go a little larger no issues and I would dress the trebles if you are bored!
jigaglow
crappies and gills mainly. number10 would be ok ? I don't tie at all but I considered putting a bead on the hook
There are several varieties of big eye hooks that you can use also. Eliminates a joining split ring.
Eagle Claw 210 (open eye)
Matzuo 1500 12 (smallest is a #6) sickle
VMC 9171 Siawash (open eye)
Gamakatsu 10006 (open eye) really like this one
Mustad 3366A (nice light wire) have a gold for soldering
Last year I picked up a huge lot of (no longer made) Mustad large eye & open eye hooks. Planning on breaking it down in smaller lots to sell or trade. Most are bronze and some blue or tinned.
For trebles I'd look for Mustad 7790-x split treble and no need for snap rings. They are made as small as size 12 but good luck finding any. I bought a bunch or 6's, 8's and 10's last summer on Ebay. Not an overly popular hook but IMO for blades is the best choice for a treble hook.
Mustad shows them as small as size 16 http://www.mustad.no/products/makers_choice/double/mc_7790_b.htm
VMC make a similar hooks but I've not tried them ---- yet. VMC 9608BZ
jigaglow
thank you guys for your help. on both of those hooks ,will I need to pinch the eye shut on hook and on the open shank do I push it back down ? I assume I will have to but I just have never used either,,thanks again
No, the hooks I mentioned slip on and with practice quite easily. Since most of mine are used on blade baits, I've gotten very good. First couple times its a bit challenging and be careful or you may break some skin. But I can easily put hooks on 100 blade baits (Vibrating blade lure) in less than 30 minutes.
