Correct lube for mold hinges
Recently I got an old used mold in excellent shape. The opening and closing is effortless and very, very smooth. This got me wondering as I only have 1 other mold that is really smooth. What does everyone use to lubricate their hinges on Do It molds. I've been using 3-1 oil and some old high temp die oil that we used to lubricate moving pins in die casting molds. I lube before and after every casting session.
Looking forward to your responses.
Good question. I've always used motor oil but noticed when I was pouring lead the hotter large castings molds could only take a certain amount of pours before the oil would smoke and scorch. I considered it a warning to let the mold rest & not continue to warp stage.
I put a drop or 2 into the pin holes AFTER every pour session since the heat facilitates capillary distribution.
I use whatever's on the shelf. Now I'm using oil made for pneumatic tools.
Airstreamfield
I use WD-40 too. My do it molds never have needed lube but my hilts get sticky occasionally. The only thing I would watch out for is WD-40 is flammable so I do it before I heat up my pot and start working. Not like it's likely to catch or anything I just like to be safe like that, it's bad enough I always walk away from my bench with small lead burns on my arms.
Sorry Airstream, the nerd in me's coming out
WD-40's not a lube, its a solvent.
Carry one.
probably the best I've found thus far is jojoba oil. Not the personal lubricant kind but an industrial version. It has great properties and is environmentally safe.
