slammingjack
- Joined
- Jul 4, 2014
- Messages
- 241
Pal of mine gave me a buck tail. So last night I tired cleaning it. I think I messed up. He told me he would have more to give me, so I want to get this right. I started off removing the bone. White side up I tired cutting a slit from the bone end to the tip. Didn't work real well so I turned it around and start at the tip. That worked a lot better. Then I cut around the hide to get the end of bone loose. Then holding the bone and meat in one hand I pulled the hide off the bone. This worked fine until I got 2/3 the way down the tail. When I got to the end of the bone the hide tore off. So I'm left with a lot of hair at the end of tail, which I couldn't get off. Ended up just throwing it out. Seem like a lot of waste. Then I washed the hide and then remove meat and whatever from the hide. Not sure what all I should have remove. Dried the water up with paper towels and with the hair side down covered the skim with Borax. Please let me know if I'm messing up here.
