jackie53 said:
AtticaFish said:Looks like you found a hook you could modify/bend to fit the bat jig mold........ what size hook did you use?
Kdog said:I like your thought process, did notice that hook is not centered in the collar which I find will reall wreak havoc during casting. Now to find an economical solution to the wire keeper ) I use upholstery staples and made a little bending jig does pretty good but not quite perfect. but I can buy10K staples for 8 bucks.
LedHed said:Great post Jackie
Have you used the Matzuo's also?
Are the staples galvanized - any rust problems?
